1980 f-250 camper special king pin replacement
i need to know exactly how to do this myself. Thanks to all that can help!
Doesn't an 80 have ball joints?
KMatch
:confused : I was asking for help!!!!!!!!!!
Dave W |
its a lot of work. The first problem is usually getting the locking bolt out. Once you get it out it usually requires a BFH to drive them out. The new bushings will most likely need to be fitted using step reamers or a hone of the proper size. I am an advocate of doing things yourself. This is a job that requires special tools and is a lot of work. If you dont have all the stuff to do it, bring it to a truck place, they do kingpins all the time.
If you don't have any experiance with kingpins but can take the front end apart safely( I don't know what your skill level is) I would take the I beams off with the spindles and drop them off at a machine shop. Let them bother with taking them apart and setting them up correctly.
get a chiltons manual...... it can explain it a heck of alot better then we can :D
| All times are GMT -6. The time now is 11:03 AM. |
