1980 GM "G" Body Lowering? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 10:26 AM
texastomeh's Avatar
Guys - I need some advice
I'm using a 1980 GM "G" Body chassis (not sure if it is a Chevy Monte, Buick Regal, etc.- it's a long story) as the donor chassis for a glass replica that I'm building. I would like to drop the frame 2" front and rear using SuspensionMax SpringTech Lowering Springs. I don't want to cut the stock springs or install dropped spindles. I physically have clearance within the wheel wells and other areas to accommodate the 2" drop.
My question is: can I do the drop as described without screwing up the suspension geometry? I realize that the front end will need to be aligned and need to make sure that I use the proper shocks - but, I've got to do that regardless.
I would also welcome any comments that anyone may have re the springs that I am considering.
texastomeh
Old 08-17-2006, 10:34 AM
STUPID is as STUPID does...
2" dropped springs will work fine. This is a mild drop and re-alignment should be fairly straight forward.
Can't help you with spring vendor though, never heard of 'em...
Mark
34 Ford body alignment 302 Z28 Body - Exterior 5 08-20-2012 06:10 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
body mounts Jzarczyn Body - Exterior 2 02-20-2004 05:20 AM
Where is GM part # for '59 corvette body? CHEV66JB Body - Exterior 0 05-14-2003 05:24 PM
