1980 gmc 1 ton
This truck has a 292 in it. I believe it's called a Mexican 4 speed transmission. Can l take the 292 transmission and bolt it up to a Chevy small block? What would have to be changed? If anything...l heard it's all the same. Thanks
should bolt up
would i use the 292 fly wheel or small block thanks
depends on what clutch your truck used? The fit is the same,most flywheels will accommodate 11 inch clutches.It should be a straight swap.
Thanks. The clutch is whatever was stock.
| All times are GMT -6. The time now is 09:44 PM. |
