1980 gmc 1 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2012, 04:27 PM
1980 gmc 1 ton
This truck has a 292 in it. I believe it's called a Mexican 4 speed transmission. Can l take the 292 transmission and bolt it up to a Chevy small block? What would have to be changed? If anything...l heard it's all the same. Thanks
Old 11-11-2012, 04:50 PM
vinniekq2's Avatar
should bolt up
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (11-11-2012)
Old 11-11-2012, 09:08 PM
would i use the 292 fly wheel or small block thanks
Old 11-11-2012, 10:33 PM
vinniekq2's Avatar
depends on what clutch your truck used? The fit is the same,most flywheels will accommodate 11 inch clutches.It should be a straight swap.
fordss (11-13-2012)
Old 11-11-2012, 10:36 PM
Thanks. The clutch is whatever was stock.
1980 gmc 3500 power fordss Engine 5 06-26-2012 09:37 AM
1980 Chevy Silverado 1/2 Ton LaPlace General Rodding Tech 1 10-19-2011 01:15 PM
1980 chevy 3/4 ton trailer brake hookup newcombcody Electrical 7 03-17-2011 04:15 PM
Disc brake conversion on a 1980 chevy 1/2 ton pickup junkman Suspension - Brakes - Steering 12 02-16-2009 04:33 PM
