1980 gmc 1 ton flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2012, 08:35 PM
it has 292 but want put early years 283 in it so what flywheel do i use for the v8.. can i use any v8 flywheel on this ? tranny 2 wheel sm456 4 speed with low any help would be grate thanks
Old 12-13-2012, 09:38 PM
RWENUTS's Avatar
Use the 292 flywheel. Same thing.
The Following User Says Thank You to RWENUTS For This Useful Post:
fordss (12-14-2012)
Old 12-13-2012, 09:56 PM
vinniekq2's Avatar
292 Vs 283, two completely different animals
Old 12-13-2012, 10:13 PM
I'm hoping 283 for the better. They said 292 will not fit. That why I need to know flywheel .. Plus 282 is not stock
Old 12-14-2012, 06:49 AM
vinniekq2's Avatar
Any reason you dont want a 350?
The 350 is cheaper,better work engine with more use able torque.
Old 12-14-2012, 07:19 AM
I have 283 no 350 and not stock it has cam ..30 over Flat top piston headers new 4barl intake. Any help be nice
Old 12-14-2012, 07:30 AM
vinniekq2's Avatar
I would really like to talk you out of using a 283 for a work truck. The 292 makes all of its power below 3500 RPM. The 283 doesnt make much torque until 3500 rpm. the 292 has a 4 inch stroke,the 283 has a 3 inch stroke. the 454 has a 4 inch stroke,,,,
I would sell the 283 and buy a 350.The cam in your 283 will make it worse for a truck engine.
The Following User Says Thank You to vinniekq2 For This Useful Post:
fordss (12-14-2012)
Old 12-14-2012, 07:49 AM
Banned
I'd keep the 292..
The Following User Says Thank You to gearheadslife For This Useful Post:
fordss (12-14-2012)
Old 12-14-2012, 08:14 AM
RWENUTS's Avatar
Check again. 292 and 283 use the same flywheel.
Old 12-14-2012, 08:19 AM
Y keep 292 ? Any help on flywheel the 283 from 65 to 67 years if this helps
Old 12-14-2012, 09:24 AM
So 283 don't use same 350 flywheel ?
Old 12-14-2012, 09:45 AM
Banned
same
yes
BRUTE POWER / PERFECTION CLUTCH Part # 506504
flywheel 283 or 350
but will your trans clutch bolt to it..
as your talking 1 ton truck
Old 12-14-2012, 11:03 AM
Would u have the link for that ? Thanks
Old 12-14-2012, 01:34 PM
So could I just a buy 350 flywheel for same truck and year ? .. Put it on the 283. Thanks
Old 12-14-2012, 01:46 PM
Banned
rockauto.com
I looked it up for a '65 impala 283
and a 80 c-10 350
1980 gmc 1 ton fordss Engine 4 11-11-2012 10:36 PM
1980 Chevy Silverado 1/2 Ton LaPlace General Rodding Tech 1 10-19-2011 01:15 PM
1980 chevy 3/4 ton trailer brake hookup newcombcody Electrical 7 03-17-2011 04:15 PM
Disc brake conversion on a 1980 chevy 1/2 ton pickup junkman Suspension - Brakes - Steering 12 02-16-2009 04:33 PM
