Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1980 gmc 3500 power
Old 06-26-2012, 08:14 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
cheap power
Some engines will tolerate a little more timing. home built water injection(water vapour) might help?
The biggest problem is breathing and a non cross flow head. The intake and exhaust are very restrictive.The cam timing is lazy.The carb is small.The air cleaner is restrictive. Fix any of these problems with what ever you can make or rob from other cars.Maybe a KnN air filter will give you 2 or 3 hp?
