1980 mustang intake,carb&heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2010, 11:47 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok Im buying an 80 notchback mustang with a 200 i6 today,is there a way to get an intake on here that will accept a 4bbl?someone told me you can't remove the intake????
Old 05-20-2010, 12:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You sure it's an inline 6? The 200 cid inline does have an integral intake, IIRC. But I'm thinking the Mustang had a V6 that year.
Old 05-20-2010, 12:26 PM
Wiki Edits: 31
200 I6's were used in '80 Mustangs..
4bbl carb is way overkill for a stock 200 6, and even a little much for a mod'd engine..
take the head off, and have a machine shop mill the intake flat, and mill .045 off of the head surface, create an adaptor that will fit a Holley 2300 2bbl. you can use an aluminum carb spacer and mod it to work... while the head is off, pull the valves and clean up the ports under the valves.. you will need washers for the head bolts that will take up the .045 removed from the head.. get a set of 1.6 RHS adjustable Rockers ( $250 IIRC ). that will make the cam a little hotter. you can also get an aftermarket timing chain and install it straight up.. from the factory, they were retarded 2*..
run, a 500 CFM holley 2300, and that will wake it up pretty good..
Old 05-20-2010, 03:05 PM
two cups of tea
Wiki Edits: 2
Good advice Ill call the shop that built my sbc&set something up.I just got it home: )
1980 mustang is it worth it? cutthroatkid Hotrodding Basics 4 05-25-2010 10:46 PM
1980 mustang notch question cutthroatkid Hotrodding Basics 2 05-14-2010 05:16 PM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 01:43 PM
