1980 Trans Am TBI Conversion wiring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2009, 04:19 PM
jrws6's Avatar
Greetings all!
My name is Jason. I have been lurking and searchin for a while... LUV the site.
Now with that out of the way. I purchased a 1990 Chevy Caprice that was originally a Highway patrol vehicle. It is my donor vehicle for the motor and tranny/ fuel parts for the 1980 trans am. I have remove and labeled the harness from the car. (under the hood part and under the dash part, and the ecm.
My first ? is in regards to the fuseblock and bulkead connector from the caprice do i need to plan to transplant these into the Trans AM or not?
Which wires need to be hooked up from my tbi harness to what wires in the original harness?
Motor and Trannny are mounted along with complete harness and ECU out of DONOR vehicle, I just cant get it to turn over.
Thanks for any help !
Old 11-29-2009, 09:00 AM
i would suggest buying a stand alone harness for the TBI rather then splice the 2 car harnesses together
Old 11-29-2009, 10:17 AM
jrws6's Avatar
Are the Stand alone harnesses any different than the one I have? Any recomendations on a brand?
Old 11-29-2009, 10:18 AM
I disagree. You don't need a standalone harness if you understand basic electronic circuits. You DO need to get a wiring diagram for both cars, however. You may need to adapt the Caprice fuse box if your original one lacks the sufficient number of circuits. I assume this is a TBI motor?
The 1990 Caprice uses a separate wire harness for the TBI and associated emissions equipment that passes through a grommet in the firewall on the passenger side, below the heater box. You need to remove the inner fender to get to it. The computer is located in the passenger side kick panel. There is also a connection to the dash wire harness and ALDL connector. You'll need to come up with a VSS since the Caprice uses a VSS that mounts to the speedometer head. If the Caprice uses VATS, you'll need to either get a bypass box or have the function disabled in the PROM. Are you planning to try to use the PROM as-is or have it tailored for your car? Of course, you'll either need an in-tank fuel pump or an inline one. Keep in mind that TBI only uses a 20 PSI pump. The Carter P5001 is a good choice for an inline pump.
Old 11-29-2009, 10:40 AM
jrws6's Avatar
thanks for the replys. Yes this is a TBI motorI have allready removed the eninge/trans and wiring harness/ecu and even the caprice fusebox, from the caprice and installed into the trans am. I was hoping to allow the ECU to run the enigne and keep the trans am fuse block in place as is. I have allready modified the TA fuel tank with the Caprice pump. Thank you for telling me the info about the TBI pumps I was wondering about that.
Old 11-29-2009, 02:28 PM
jrws6's Avatar
I plan on using the PROM as is and leaving the motor stock. I need a VSS that screws into the transmission speedo hookup.
From what I can tell I need to supply power to the folowing wires:
IGN PWR
Battery Power
Ground Connection
Fuel Pump
AC Compressor
Crank Signal
What Else?
Old 11-29-2009, 02:46 PM
http://v8s10.com/Pages/SpeedSensors_Speedometer.html
Disc brake conversion on a 1980 chevy 1/2 ton pickup junkman Suspension - Brakes - Steering 12 02-16-2009 04:33 PM
305 to 350 tbi conversion what chip?? jackfrost51 Engine 1 02-19-2003 04:35 PM
??I NEED HELP WIRING 2000 S-10 CONVERSION Luap Engine 0 12-09-2002 04:43 PM
67 Cutlass manual trans conversion BuckeyeX Transmission - Rearend 0 12-05-2002 07:08 AM
TBI conversion to Carb Seon Engine 0 10-15-2002 03:20 PM
