Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1980 Vette Brake problem
Old 07-05-2012, 09:10 PM
timothy9972 timothy9972 is offline
I have disconnected the 8 inch metal line that runs from the rubber line to the caliper and I am getting no fluid to this point when pushing the pedal. So I took the line off the proportioning valve and blew thru the line with an airline. This blew all the fluid and everything out of the lines and both lines at both wheels had air blowing out them. Reattached the line to the valve and pushed the brake pedal and still am not getting fluid to the back of the car. So since the valve is new the only other option is that the line from the MC to the valve is clogged, the MC needs to be bled again or it is defective.
