1980's rear main seal ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2008, 07:02 AM
350 sbc 4 bolt main 80-86 BLOCK the rear main or pan gasket is leaking
Is this a 2 piece design or one and can I change it with the pan removed and flex plate in place still in the truck if it is a 2 piece one?
Can I remove the rear bearing cap anf put in a new seal or maybe slide the top part out also and slide in a new top half?
Old 01-17-2008, 07:51 AM
staleg's Avatar
Last journal entry: Hand brake
This is a 2 piece rear main seal block.
Old 01-17-2008, 09:04 AM
yes you can get a eye full ,but yes it can be done .
they sell a tool to fish out the top half of seal put i prefer a butter knife with the end tip ground flat and cutting edge ground down to .
you can bend the knife some to get it to push out the bearing till you can grab it with needle nose pliers .
got any spray adhesive ?
spray gaskets and block to keep cork gasket up in place .
be sure to wipe block of oil with brake cleaner or paint thinner.or
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
55 chevy, 265 rear main seal slingslingbinks Engine 5 10-19-2004 09:27 AM
Oil Leak. Rear Main Seal?? 7skylark6 Engine 6 04-27-2004 03:20 PM
Rear Main Seal Silentlion_69 Engine 5 12-06-2003 06:34 PM
rear main seal in 350 bstm23 Engine 4 12-02-2003 12:57 PM
