1981 Camaro fuel cell wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2010, 01:03 PM
I just bought a 16 gallon fuel cell for my Camaro and it has a GM sending unit installed and I was wondering how to hook up my stock fuel sending unit line to the two posts on the cell?
Old 03-17-2010, 01:16 PM
ericnova72's Avatar
More for Less Racer
Wire from guage goes to one post on cell, the other post gets a wire hooked to chassis ground. If it reads incorrect(full when empty)just reverse the wires on the posts.
Is the sender the correct ohm resistance scale to match your GM guage??
Never mind, I see you said GM sender.
Old 03-17-2010, 08:28 PM
Thanks for the info, will try the wires tomorrow.
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
Fuel Cell Fix Conrad Smith Sr Hotrodding Basics 7 04-13-2009 06:54 AM
AutoMeter gauges, Fuel Level, Painless Wiring stratt134 Electrical 12 06-13-2006 08:06 PM
Fuel Cell Foam or not Scoops Engine 2 01-23-2006 05:39 PM
Fuel Cell Problems Stupido1 Engine 5 08-13-2005 09:17 PM
