1981 Camaro shifter parts replaceable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 01:21 PM
Hello all,
The factory stock console shifter in my 81 Camaro is very sloppy. There's lots of fore and aft slop and when trying to shift from low range up through the gears the shifter frequently jams and I have to wiggle it back and fourth a few times to get it to finally shift to the next gear.
I took the top cover off to take a look and there seems to be plastic pieces that run in a track thats suppose to keep the shifter tight and smooth. These plastic pieces look pretty well worn out. (see pic at link below)
http://i20.photobucket.com/albums/b2...ro_Shifter.jpg
I would like to repair the shifter if possible because I cant afford to replace it with a aftermarket slap shifter like I want to eventually do, so my question is what are those plastic pieces called and where can I buy replacements? How hard are they to change?
thanks
Old 09-13-2011, 05:56 PM
pricesgarages's Avatar
usually the cable is bad and make sure u have a ground strap on the trans those 2nd gen camaros and firebirds would groung threw the cable and make them sieze up
Old 09-14-2011, 02:09 PM
I went ahead and removed the shifter. The side bushings look pretty well worn.
Does anyone know the proper name for these and where I can buy some new ones?
its the plastic piece on either side of the shifter held in by 2 bolts (see pic below)
While I have everything apart I plan to also replace the shifter cable.
thanks
Old 09-14-2011, 05:20 PM
SSedan64's Avatar
A Restorer parts Shop should have them. Year One, OPGI etc... or any of the Camaro restorer Co.'s
Ricks is one> http://www.rickscamaros.com/transmis...-shifters.html
Old 09-15-2011, 06:28 PM
Wow these bushings must be made out of unobtanium.
I called Rick's and they didn't have any and said they had no idea of any other place that might.
I've browsed eBay, checked the website catalogs of tons of restoration parts companies and cannot find them anywhere.
I was hoping it was going to be cheaper to replace these 2 little bushings rather then replace the shifter with a aftermarket unit, but that's starting to look like my only option.
Does anyone know what the proper name for these bushings are and/or where they might be perchased?
thanks
Old 09-18-2011, 01:00 AM
streetrodderbn's Avatar
Certifiable Streetrodder
it's cheaper to buy the whole shifter on ebay and take the parts off. There are at least 2 shifter assemblies on there for $39.00 and shipping. I have a 78 z28 shifter lying around somewhere,I'll look tomorrow.
Old 09-18-2011, 07:19 AM
SSedan64's Avatar
Are you sure those are the worn parts?
Nylon will usually wear the Steel before the Nylon wears. Normally the Gate detents wear & Springs weaken.
Old 09-18-2011, 08:28 PM
thanks for the help guys..I just bought a used B&M Quicksilver on ebay for $131 shipped..that's a lil pricey for used but the guy claims it's like new.
1981 camaro z28 headlights fishermen199 Electrical 3 09-06-2011 04:09 AM
1981 Camaro shifter problems lizardking7750 Transmission - Rearend 26 03-12-2010 07:19 PM
1981 Camaro M/C question staleg Suspension - Brakes - Steering 3 03-07-2007 07:51 AM
1981 camaro 81blownz28 Engine 5 08-23-2004 06:51 AM
1981 dodge b150 customizing parts fuelhauler Introduce Yourself 0 08-06-2004 08:44 AM
