1981 chevy scottsdale exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2010, 12:50 AM
hey guys im wondering if anybody has ever built a custom exhaust for the 80s model chevy pickups im working on trying to build true dual exhaust on it but i dont wanna go under my transmission crossmember because of clearance issues and im being told its bad to put 90 degree angles in exhaust please help me if u can thank u
Old 01-07-2010, 08:22 AM
4x4 or 2WD? Some of the trucks had a double hump transmission crossmember,as some had true dauls from the factory.
Shane
Old 01-07-2010, 08:29 AM
70455's Avatar
On a 2wd you can go under the crossmember. On a 4x4 you have plenty of room on the drivers side above the crossmember on the right side you have to go between the transfer case and the frame.
Old 01-07-2010, 01:33 PM
81 scottsdale exhaust
it is a 4wd and i have enough room for going over the crossmemeber on the driver side and could possibly do it with a couple 45s then just straight pipe it but on the passenger side i have the t case hump and front drive axle that is in the way and i hear that id need to use 90 degree bends to get up over the t case but idk what to do
Old 01-07-2010, 02:35 PM
fast68's Avatar
likes chevy trucks & boobies
our 82 k10 both pipes are over the x member just fine
i dont see the problem
it has headers full length,
maybe that is why
Old 01-07-2010, 03:40 PM
fast 86
really fast 86 mine is the long box version of the scottsdale and i have long tube flow tech headers from oreilleys and the center of the collectors hit right smack dead center of the cross memeber so i have to kinda build a camel hump over the cross member but idk if its safe to use 90 degree bends in the tubing or not what do u reccommend?
1981 chevy truck HEI ignition problems Brad Wiley Electrical 3 12-29-2006 11:26 AM
Did Chevy change the exhaust manifold bolt pattern on small blocks? STATUTORY GRAPE Engine 7 05-13-2005 05:34 PM
1981 Chevy Truck Tponykid Engine 6 03-24-2003 06:03 PM
80' chevy c10 fulsize truck...exhaust chevyteen17 Engine 2 02-16-2003 12:14 PM
Exhaust Questions for 56 Chevy; cutouts, mufflers.... Mr.56Chevy Engine 1 02-16-2003 08:43 AM
