1981 f150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 06:58 AM
1981 f150
hi out there i have a 1971 460 mark111 in my 1981 F150 lots of oil presure when cold idle hot no presure when you step on the gas engine dies let of gas engine picks up no lifter noise
Old 08-05-2012, 07:21 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like it might be running out of fule under a load JMO are you running a electric pump or mechanical pump ? and just what do you measne by no oil pressure under a load 0 or exaclty how much are you calling none ? could be the picup tube or just not full of oil and when it is under a load it moves away from the pickup tube. JMO
Cole
Old 08-05-2012, 07:36 AM
eloc431962's Avatar
Wiki Edits: 37
Oh and welcome aboard.
Cole
Old 08-05-2012, 01:35 PM
Bad oil pressure
Hi cole and thanks what i mean is when i first start cold engine 50lbs oil pressure when engine gets to temperature oil pressure dropes to zero its a 1971 460 LINCOLN MARK111
Old 08-05-2012, 05:55 PM
eloc431962's Avatar
Wiki Edits: 37
Is it making any noise ? could be bearings JMO.
Cole
1981 ford f150 300cid c-6 transmission sixbang_her Transmission - Rearend 2 01-26-2009 08:47 PM
1981 ford f150 300cid c-6 transmission porkchop480 Transmission - Rearend 8 10-27-2008 12:16 PM
f150 shade tree don Introduce Yourself 1 05-27-2006 01:21 AM
1981 camaro 81blownz28 Engine 5 08-23-2004 07:51 AM
V8 1981 S-10 Joseph_1026 General Rodding Tech 7 11-26-2003 05:30 PM
