1981 ford 302
How much horse power will a stock Ford 302 2bl out of 1981 LTD? It has 76,000 miles and runs great. I would like to put in in a 80's Mustang for a cheap drag car.
Thank you |
I did and the range is 135 to 225.
302, trany, drive line, radiator $200.00, 1985 mustang gutted $ 500.00, gears $ 150.00, intake and carb $500.00, slicks $400.00, Misc $ 500.00, high 13's ?
You need a bigger budget
You probably have the worst heads on your 302 from a performance stand point you could ask for since you are on a budget you may want to look locally for these:Ford GT40 Cylinder Heads | eBay with the GT-40 head you can use your existing pushrods and parts.Yes,there are a lot of great aftermarket heads that will make more power but prepare to spend upwards of $1400 to go that route because of parts and modifications to fit them.
Thank you JeffB!
go to your local boneyard and look for a 5.0 ford explorer and rip the heads off they come factory with gt40p heads, the junk shouldn't charge you more than $200 for the heads although if i was doing a junkyard build id use a 87-92 mustang 302 engine since they have factory forged pistons and are roller motors
The downside to the GT40P heads is they will not clear most header flanges due to the spark plug angle being changed,no problem with the regular GT40's.You will find plenty of threads on the web where guys tried using the GT40P's and got in a mess and are looking for a way out.
| FORD 302 vice FORD 302 Hipo | Kauai Hawaii | Engine | 6 | 11-09-2008 01:27 AM |
| 1948 ford f-1, 1981 ford f-150, mustang ll pile up | derrick_500 | Suspension - Brakes - Steering | 6 | 09-09-2008 01:17 AM |
| 1981 Ford 302 HP?????? | derrick_500 | Engine | 32 | 01-23-2008 12:30 PM |
| Ford 300 1981 | ivansolorio | Introduce Yourself | 2 | 07-11-2007 08:25 PM |
| 1981 F-150 302 | oliver28472 | Engine | 9 | 11-25-2002 12:55 PM |
