1981 Gm 3.6 V6 Rough Idle And High Idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2007, 06:24 PM
nomaddaddy's Avatar
Nomaddaddy
I have a 1981 El Camino with a 3.8 v6 that won't idle down and also idles rough. I have check all the obvious. I am led to believe there is a problem with the electrical idle circuit in the carb. Any help??
Old 11-15-2007, 09:49 PM
sounds like the carb, the solenoid appearing thing in there probably just shat, you can buy them separate but it should be easier to buy a reman carb from auto zone or whichever parts store you got around there.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam lope question joeford Engine 4 08-10-2006 08:14 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 08:56 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
