1982 700R4 input shaft spline - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2008, 09:37 PM
Trying to order converter for what i believe to be an 1982 700R4...I am trying to figure the spline? I read it may be a 27 spline..anyone know for sure?
Thanks
Old 10-08-2008, 10:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
A 1982 700 trans would have a 27 spline input shaft. Unless it was updated to the later 30 spline shaft. The update requires many parts to be changed
I would suggest counting the splines on the input shaft
Old 10-12-2008, 06:29 AM
Wiki Edits: 85
V8 had 27 spline original with a polished tip. Many were updated to 30 splines.
L4 & V6 had NO polished tip. Think they were all 27 splines.
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
T-400 Input Shaft Bushing 68NovaSS Transmission - Rearend 0 12-30-2003 06:03 PM
Input shaft conversion for C4 k2mooch Transmission - Rearend 8 12-29-2003 10:36 AM
94 Camaro /Borg Warner M49 Input Shaft Play rocndav Transmission - Rearend 1 10-27-2003 08:49 PM
leaking input shaft 67bucket Transmission - Rearend 0 08-18-2003 10:58 AM
