1982 buick regal engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 02:32 AM
i got a clean 82 regal with a junk non turbo v6 can anyone help me to guid me to the best engine and tranny setup for this car and how hard is the swap thanks
Old 05-24-2010, 03:02 AM
Not sure what you would consider the "best" set-up, but the easiest would be SBC/T350. Definitely the easiest, and probably the cheapest too. G-body parts are all over the place, new and used.
Old 05-24-2010, 05:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your Regal will fit any number of GM engines- everything from a 200 cid V6 to a GMPP 572 BBC is pretty much a bolt in. Pontiac, Olds and Buick engines will all fit w/o drama. The Cad 425/472/500 will also fit, takes a little more as far as motor mounts and such.
If you consider all the things you want the car to do well and compare that to your budget, your choices will be pared down some.
But personally, I think this car would be ideal for an LS-type engine in it. Costs more going in, like around $500 for the intake and ignition controller, but after the initial hit, these engines ROCK! Great potential, NA or boosted, w/o needing rad cams and such.
Old 05-24-2010, 09:57 AM
The EASIEST is to replace the Buick V6 with a Buick 350. EVERYTHING bolts up. A Buick 455 would be even better, but you need the 455 accessory brackets.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Camero Engine swap Bugs Engine 14 10-28-2005 01:38 PM
Engine Swap - 64 Galaxie Billy Boy Engine 5 07-21-2005 02:49 PM
326 firebird engine swap with a 400 engine...is it possible?? greg67 Engine 7 11-08-2003 03:34 AM
