Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1982 Chevy K10 Suburban gear ratio ?
Old 06-05-2011, 08:34 AM
GMCBEAST's Avatar
GMCBEAST GMCBEAST is offline
Originally Posted by Bryan59EC
3.73 was real common for the 2wd trucks
I had 4.10 in my 78 k-10 pick-up
If you only get 10mpg at any given time-----4:10
if anything better than 12---3.73
There will be a code stamped on the rear end somewhere (I think right side top) that someone can probably decode for you.
Once I get the stamped code off the axel tube where can I check it at? This is how I used to ID old F-Body rears but couldn't find anything on trucks. Thanks.
