1982 Chevy K10 Suburban gear ratio ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2011, 03:44 PM
GMCBEAST's Avatar
I have a 1982 Chevy K10 Suburban, 350cid/700r4 4x4. The RPO code sticker is missing from this truck. I have searched high and low on the net to figure out as much as I can about the running gear in this truck. Does any know "typically" what gears and diff came in this particular model or where I could start looking for some info? I appreciate any and all help. Thanks.
Old 06-04-2011, 04:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title to give the folks here an idea what help you need with the rear end.
You can check Here On the Crankshaft Wiki article... there are some ideas there to help figure out the gear ratio. With the age of the vehicle it may have been changed once
Old 06-04-2011, 07:15 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
3.73 was real common for the 2wd trucks
I had 4.10 in my 78 k-10 pick-up
If you only get 10mpg at any given time-----4:10
if anything better than 12---3.73
There will be a code stamped on the rear end somewhere (I think right side top) that someone can probably decode for you.
Old 06-05-2011, 05:10 AM
willowbilly3's Avatar
Last journal entry: Body mods
I think the last one I had, an 85, had 3.42s, but it was a grease burner.
Have you looked in the glove box? There is usually a sort of line setting sheet stuck inside the lid and it may tell you if there was an optional axle ratio ordered.
Old 06-05-2011, 07:10 AM
LATECH's Avatar
My experience has shown a lot of them were a 3.08 due to the epa squeezing automakers for fuel mileage.If it is a 3/4 ton and not a half ton then probably a 3.42.JMO
Too bad the rpo label is gone
Old 06-05-2011, 07:11 AM
The table on this page will give you the possible choices:
http://www.chuckschevytruckpages.com/73-87specs.html . Since its a K-10, it looks like 3.23 and 4.10 are possibilities. The table seems to say that 3.42 and 3.43 were only used with smaller engines, but I might be reading it wrong.
Many of these trucks don't have the ratio on the RPO sticker if it is the stock ratio. It may only be listed if it is an option. My truck had a metal tag on the rear end pumpkin, and you could use it to figure out the ratio. It did not say 4.10, but instead showed the number of teeth on the gears - something like 45/11.
Bruce
Old 06-05-2011, 07:34 AM
GMCBEAST's Avatar
Once I get the stamped code off the axel tube where can I check it at? This is how I used to ID old F-Body rears but couldn't find anything on trucks. Thanks.
Old 06-05-2011, 07:40 AM
GMCBEAST's Avatar
I truthfully am expecting 3.08's to be honest, there is nothing special about this truck, it seems very run of the mill. Hoping it is a posi at least, I have a newer model Jimmy that has a decent running gear in it that I'm not sure if I want to swap or not, all depends on the setup this 'Burban has. Thanks.
1956 Chevy sedan rear end gear ratio? goodold56 Transmission - Rearend 3 02-28-2011 07:11 PM
1987 Chevy shortbed 4x4 gear ratio questions newattruckin Transmission - Rearend 6 05-09-2010 06:13 PM
57 Chevy gear ratio? CHASINGJR Transmission - Rearend 6 10-29-2006 09:10 PM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 07:49 PM
chevy suburban gear disassembly xtremcablespeed Transmission - Rearend 1 12-11-2003 07:48 PM
