1982 cutlass 307 idle issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2013, 04:38 PM
does anybody know what a 1982 cutlass 307 is suppost to idle at?
Old 03-07-2013, 04:52 PM
LATECH's Avatar
Last journal entry: New Gas Tank
There should be an emission sticker underhood with the specs on it.
I would think that 650 in gear would be correct. Engine warmed up fully AC off.
Fact is stranger than Fiction
Old 03-07-2013, 05:50 PM
Ill have too look i tried to ajust my carb cause when i crank it on it will idle really high then i give it some gas and slows down a bit but still high
Old 03-07-2013, 06:06 PM
LATECH's Avatar
The CCC carb by GM is not a DIY carb. They are pretty complicated, and when they start to act up , usually they need rebuilt.
If the check engine light is on you need to figure out why.
Trying to adjust one of those probably wont work out well , at least until after a rebuild.
Old 03-07-2013, 06:13 PM
The carb is a edelbrock
Old 03-07-2013, 06:36 PM
LATECH's Avatar
625-650 rpm in drive should work nicely.
Old 03-08-2013, 11:56 AM
Have you adjusted the choke high idle speed at all?
Are you using a non-CCC distributor?
307 cutlass carb/idle problems theguesswho Engine 1 09-08-2012 11:29 PM
olds 307 frost plug and idle problem theguesswho Hotrodding Basics 2 09-02-2012 02:11 PM
Idle issue - 96 ranger 406 bug Engine 3 03-15-2010 08:26 AM
1982 cutlass supreme gears? eatonde Transmission - Rearend 2 08-09-2008 02:05 AM
Fast Idle Issue ruiner808 Engine 3 01-20-2004 01:20 PM
