1982 k5 blazer w/305 want to install a 700R4 trans
I have a 1983 K5 Blazer 2 wheel drive with a 305. My Transmission just went out which was a 400 3 speed and I want to change it for a 700R4. Can I do this if so what problem will I have. all I really know is that the 700R4 has some electrical components. I'm not to savay on transmission. Thanks
Are you sure you had a TH400 in an '83 K5 Blazer? It should have had an overdrive automatic already by 1983, or maybe a TH350.
The swap to a 700R4 is fairly easy, but you want one of the late 80's versions, after they improved the reliability. You do need an electrical kit to activate the lock-up torque converter. Bruce |
I do have the 400 the guy before me put it in. How difficult is it to install the electrical kit.
This article might give you a better idea of a simple electrical installation - he uses a manual switch. http://www.smokemup.com/tech/700r4.php
This kit is fully automatic http://www.tciauto.com/Products/Inst...76600_inst.htm Bruce |
| 700R4 Trans Pan Leak | happydad | Transmission - Rearend | 4 | 08-21-2008 03:16 PM |
| 700r4 trans shift problem | daddy358 | Transmission - Rearend | 2 | 10-26-2006 03:56 PM |
| S10 700R4 to 76 Blazer swap | Drewnashty | Transmission - Rearend | 6 | 06-12-2006 09:30 PM |
| 350 4x4 trans to 700R4 2x4 trans swap??? | punk1c5040 | Transmission - Rearend | 1 | 02-01-2004 11:14 AM |
| 74 K5 Blazer body | swoo55 | Body - Exterior | 2 | 10-26-2003 05:19 PM |
