1982 Trans Am W/ BW T 10 - using torque arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2007, 07:06 PM
Hi guys. I'm new to this board, and I am running into a problem with my Trans Am. It has a Borg Warner T 10, which made no provisions for the torque arm. When I bought the car, it had a straight piece of steel welded to the mount, which I broke about 5 times in the first 8 mos I had the car. I got tired of that, and wrapped a ratcheting tie down strap around the damn thing, holding it tight to the shifter, which broke the bolt hole in the tailshaft. I am thinking about this as a fix - Using a 1/8 in thick, 1 1/2 in tall angle steel, bolting the end of the torque arm through it using the 2 stock holes. Then, drilling a hole through the tranny crossmember, bolting the fabricated mount to the crossmember. Does this sound feasible, or do y'all think it will break?
Old 04-23-2007, 06:39 PM
top.......
trans am rear 10 bolt Rough-Rider Transmission - Rearend 2 03-22-2007 08:48 PM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 04:11 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
