1983 chev trans slips - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-15-2006, 10:54 AM
Thank you for posting back. Is reverse ok?
Although reverse may not matter,slipping in all gears is not good.
  #17 (permalink)
Old 12-15-2006, 11:50 AM
It works fine in reverse.Doug
  #18 (permalink)
Old 12-15-2006, 01:39 PM
Unfortunately Doug there are only two simple things you can check that may create this situation,that I can think of.
First is fluid level. Second is tv cable,out of adjustment,low tv pressure rise.
Are you familiar with checking tv cable? Over time,the cable can stretch,which would cause a low tv pressure condition. This would make the trans slip.
  #19 (permalink)
Old 12-16-2006, 12:57 AM
The fluid is full, and i don't know how to adjust the tv cable.thanks.Doug
  #20 (permalink)
Old 12-16-2006, 09:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I do not see a history on this tranny in this thread.
Mileage ? , recent repair or rebuild work?
At the carb where the TV cable is hooked...... someone needs to sit in the vehicle ( engine OFF) push the gas pedal to the floor.
Pull on the TV cable while the trottle is held to the floor . Then check for full pull at WOT ( Wide Open Throttle). Check for a loose cable at WOT.
Is the cable hooked up?
If you can not preform this procedure , find a knowledgeable tranny shop or person to help....... good luck.
post back if you need more help.
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-12-2006 12:24 AM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 05:11 AM
36 Chev Hot Rod Brake System 36Chev Suspension - Brakes - Steering 8 02-15-2006 01:39 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
305 Chev looking for flat 14's nicefrog Engine 2 12-04-2002 07:16 AM
