1983 chevy kings highway motorhome starter circuit diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 09:33 AM
I am having trouble starting my 454 gm engine ..solenoid just clicks..and the starter works when i put power to it before I installed it
Old 07-17-2011, 01:56 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Make sure the battery cables are making good contact. It is possible that there enough power to make solenoid click but a poor connection won't be enough for the starter load.
Even a battery cable that looks good can have hidden corrosion at the terminals.
Make sure the engine ground cable is making a good connection.
A quick test is to, using a jumper cable, connect the large bolt on the starter solenoid to the battery + terminal then try to start the engine.
vicrod
Old 07-17-2011, 02:53 PM
The large starter cable is probably a little loose at the battery or at the starter. Its hard to reach on the starter end, and sometimes hard to tell if its tight enough. The other possibility is that the battery needs to be charged.
There isn't much more to the circuit. If you are getting a click, then the ignition is activating the solenoid, but it does not have enough power to kick out the drive gear and turn the engine.
Bruce
Old 07-17-2011, 08:08 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
A bad solenoid will do it fyi
"not having enough power to kick out the drive gear" not exactly the way it works.
The click is the solenoid operating, it is linked to the starter drive gear and if you here a click the gear in moving.
The problem is the contact, a round copper disk is not able to pass current to the starter and energize the starter motor. There are two lugs one has the + cable attached and the other is for the starter motor, more then likely there is pitting.
You could take the solenoid apart and clean up the area and it will work. But a replacement is the preferred method.
Of course this would be the case only if you know the cables are tight and the battery is good.
i desperately need to find a wiring diagram for a 1983 f150 please help if anyone can bigblock0926 Electrical 11 04-11-2011 10:27 AM
need 85 or so F150 charging circuit wire diagram fast68 Electrical 4 05-28-2010 08:57 AM
Starter wiring 1983 chevy pickup zz71s Electrical 1 04-07-2010 08:50 PM
350 Chevy Motorhome with Rochester ASQUARED Engine 7 06-10-2009 05:28 PM
1983 Ford F-150 Pick-Up Truck Wiring Diagram wojy37 Electrical 4 01-05-2003 09:35 AM
