1983 ford inline 300 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2007, 02:57 PM
this bronco is from out of cal, this is the third motor, it is running lean and burning valve! i said to run cooler plug and change out the cat on back.
what do u all think
Old 02-03-2007, 03:00 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I'd say you have a timing problem or plugged cat causing exhaust to run hot.
Old 02-03-2007, 07:19 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
those things are real bad about the intake warping and causing a vac leak.
Old 02-03-2007, 08:21 PM
warping
that happened has been fix, new carb ,new intake,
Old 02-04-2007, 05:36 AM
I don't have any experience with 300s but out here the 250s burn intake valves (!) before exhausts. Some blokes drill and tap the heads for a top water outlet and claim it helps valve life.
I've done a few 302/351w F150s from the early 90s that blocked cats after a head gasket failure - coolant always kills cats. They all burnt out #8 exhaust valve,and the customers complained of a hot l/h floor.
Ford 300 six cylinder custom head Chris Kemp Engine 19 01-26-2016 08:56 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Ford 240 inline six carnage onebadmerc Engine 5 01-16-2005 07:33 PM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
Decoding Ford 300 6 tag on timing cover Duner Wi Engine 3 02-06-2003 11:36 AM
