1983 Z28 rearend problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2013, 08:20 AM
Hello. New here I have a 83 z28 the axle codes match for a posi vin mubers too.have read several posts none seem to match my ? I turn wheels by hand other doesn't move at all did have new ring and pinion installed yrs ago. Is it just wore out or could the mechanic have ripped me off and taken my posi unit and put a different unit in. I'm second own .er. Previous never had anything changed .
,can anybody help thanks
Old 07-06-2013, 09:28 AM
I'm thinking your Auburn posi is just worn out. It will act like a regular open diff when the clutch wears and dissipates all the preload.
Old 07-06-2013, 09:43 AM
Does sound like a concrete grinder thanks a bunch
Old 07-06-2013, 10:36 AM
Banned
well to find out both of you questions, only way is to open her up and see what you got.
Old 07-06-2013, 11:29 AM
I did no springs tried to get numbers on carrier can't see any think I was dupped went to auburns web site didn't look the same
Old 07-06-2013, 12:42 PM
big gear head's Avatar
High Performance Rear Ends
Can you post a pic?
The '83 would have had the Auburn limited slip differential. When they wear out they stop spinning both tires and at this point they are scrap metal. You can not rebuild them.
Here is something to think about. The 7.5 rear end uses a 2 series differential for 2.14 to 3.08 gears and a 3 series differential for 3.23 to 4.56 gears. If you had a 2 series Auburn and you went to gears in the 3.23 to 4.56 range then the guy who put the gears in might have swapped your 2 series Auburn for a 3 series standard differential so that the gears would fit.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (07-06-2013), Tom' (07-07-2013)
Old 07-06-2013, 02:22 PM
Car came with 3:73 went back with same will post pic I really appreciate the responses guys
Old 07-06-2013, 02:50 PM
I dont think it came from GM with a 3.73.
Old 07-06-2013, 02:53 PM
All the numbers match up with 3:73 vin 5jq is the axle code hayn
es manual says 3:73 posi
Old 07-06-2013, 03:11 PM
I have pic on profile thanks again
Old 07-06-2013, 03:40 PM
Thats definitely a standard open diff.
I hate to see people get ripped off by mechanics.
Old 07-06-2013, 05:00 PM
Thanks he's no longer in business. Good for him
Old 07-06-2013, 05:22 PM
If it's an original 3.73 Auburn rear end then it will have RPO coded GT4 and G80 on the sticker on the bottom of the console lid or on the back of the spare tire cover.
Just looked at the pic and that is a standard differential. If you had an Auburn then it's gone now.
If you decide to put another differential in it I do NOT recommend using another Auburn. They are at the very bottom of my list of good differentials. I would recommend using a Eaton Posi, Eaton Truetrac or a Yukon Dura Grip, depending on what you want to do with the car. I would also recommend upgrading your 26 spline axles to the later 28 spline axles at the same time.
Old 07-06-2013, 07:34 PM
Are these manuals known to wrong. Will check spare cover
Old 07-07-2013, 06:24 AM
Motor has about 330hp just put a world class t5 in .not going to race it but want to do it right without going over board ,is this enough info for a suggestion of what I should get 28 spline definitely. Thanks
how can I tell if my rearend is posi in my 84 z28 Celtz Transmission - Rearend 17 03-08-2012 05:35 PM
96 Z28 shift problems gixerjockey Transmission - Rearend 9 09-16-2010 04:37 AM
85 z28 rearend StrokerBoy383 Transmission - Rearend 1 07-08-2008 05:55 PM
2002 z28 camaro rearend boola Transmission - Rearend 1 05-10-2007 10:07 PM
1983 2.5 chevy eng problems 71montebbc Engine 15 01-17-2005 07:18 AM
