1984 305 polution problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 04:42 PM
i have a 1984 el camino with a 305. it has this thing that has hoses coming off it and going nowhere. i think its something with the polution, and i need to replace this part and find out where all the hoses go. can anyone help me out?? it was bolted on right by my alternater.
ID:	63701   Click image for larger version
Old 03-04-2012, 05:02 PM
LATECH's Avatar
It is the Air Injection Reactor valve. It controls the air from the air pump .the valve can either dump the air in the exhaust upstream at the exhaust manifolds or down at the cat.Chances are the air pump is gone, as well as the AIR tubes at the manifold. Does it have a cat?
Old 03-04-2012, 06:27 PM
Well
i think its all there. pump is there. and yeah there is a cat. there is the one hose u see in the pic with the shiny metal end. i wanna know where that use to go??
Old 03-04-2012, 06:40 PM
LATECH's Avatar
the small hose was for the solenoid that controlled the vacuum. You should try to find a vacuum diagram for it. I dont recall the intimate details, but it has a solenoid to control vacuum, turns on only when engine is warmed up to operating temp, and it could have one to switch the valve from upstream to downstream, or vent to atmosphere as well.If you look at the part closely,it may have some markings on it that can help you figure some of it out.
Old 03-05-2012, 03:55 PM
sorry
im sorry, but u were right. the cat is gone, and i dont see any sylenoid or anything. should i juss plug this stuff off or should i do it right and get a cat and sylenoid thing that i need, man it helps to know what something looks like when ur trying to find it. lol if i should plug it all off, what would be the best way to do so?
Old 03-05-2012, 05:32 PM
T-bucket23's Avatar
Wiki Edits: 26
Those had some sort of check valves if I remember and when they went bad the hot exhaust would get to the plastic valve and melt them
Chet
Old 03-05-2012, 06:40 PM
LATECH's Avatar
About the only thing needed from the sound of it, would be to bypass the air pump by putting a shorter belt on the engine.If your state doesnt require emission testing, let it go. Otherwise you can get an aftermarket cat, and all the goodies to put the A.I.R. system back together.
Old 03-05-2012, 08:57 PM
I found myself in the same situation. Redo some 30 year old emmision system for what ever thats worth. Or simple plug it and run just as good. If your are trying to keep things stock/original then redo it. Or simply plug it but leave it in place. With weight savings, extra load on the motor, and clearing up clutter so the engine especially around the carb can have cool air flow I have started to remove some things.
Old 03-06-2012, 01:05 AM
belt
any idea what size belt i could get to bypass the pump?
Old 03-06-2012, 05:37 PM
LATECH's Avatar
The parts counter guys will know, just have to go.
Old 03-06-2012, 10:42 PM
belt
there was a belt going from the crankshaft juss to that pump. so, i juss took it off...
Old 03-06-2012, 11:31 PM
wow, so great!
1984 700r4 trans problems ccrazyhevy Transmission - Rearend 2 12-30-2011 10:24 PM
1984 chevy sv2 van with tranny problems BillySauce Transmission - Rearend 1 11-28-2011 04:02 AM
1984 700r4 shift problems roadman65 Transmission - Rearend 1 02-16-2011 02:10 PM
Check this out an answer to polution and hotrodding ChevyThunder Hotrodders' Lounge 1 10-13-2006 12:38 PM
Polution Control Junk dollybud General Rodding Tech 2 11-18-2003 01:47 AM
