#1
1984 305 wiring
I'm in the process of puttin a 305 in my truck and all I need to do is wire it and hook up vacuum lines..problem is I'm not sure how to do either one..please help
Register now (free) or login to remove ads |
#2
Identify component, verify vacuum source type, and attach hose.
#7
Welcome to the board, but...read the guidelines, I merged your two threads together, please don't double post.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne Midnight Sun Street Rod Association |
#9
If the original wiring is still intact, There are very few wires required to connect to the engine.
There is a wiring loom that runs across the back of the engine compartment near the left valve cover. That has these wires: - wires running to the alternator BAT terminal and the two wire plug on the alternator (3 wires). - start wire and fuse box power wire running down to the starter (2 wires) There is also a power wire running to the HEI, and there may be a tach wire running to the HEI. You also need the large (red) battery cable running from the positive battery terminal, and the black battery cable from battery negative to a ground point on the alternator bracket or engine block. Other wires you may have: - A/C compressor (dark green) - temp gauge sensor (green) - choke power wire (color?) - A/C idle solenoid Bruce |
| Thread Tools | Search this Thread |
| Similar Threads for: "1984 305 wiring" | ||||
| wiring digraham 1984 chevy caprice classic | zealous pal | Electrical | 1 | 07-23-2011 06:29 PM |
| 305 Gm 1984 225 Hp | minis21 | Engine | 1 | 11-19-2006 07:13 PM |
| 700R4 1984-87 GMC PICKUP wiring | will8243 | Transmission - Rearend | 3 | 06-03-2005 08:14 AM |
| Wiring 1984 Chevy Caprice Classic | kringold | Electrical | 2 | 05-30-2005 05:48 PM |
| 1984? | 87442lover | Hotrodders' Lounge | 4 | 07-29-2004 04:09 AM |
