Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 350 C10 Silverado electric choke
Old 10-14-2012, 05:00 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Check the wire at the choke cap for 12V with the ignition switch on. If no 12V then run a wire from a 12V source when the ignition is on. Could be an unfused plug in on your fuse box to use.
