Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 351W into a 1966 Ford Fairlane 500 Convertible
Old 02-19-2009, 11:41 AM
hotrod charlie hotrod charlie is offline
Last journal entry: 32 ford coupe
Your 351w will fit. They use the same motor mounts and bellhousing as a 289 302 and even the early modle 351c. Your headers will also fit but they will be colse to the oil pan because the 351w has a 1 inch taller block height. The 351 uses a diffrent oil pan and intake. Only the 351W will fit
