1984 700r4 shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2011, 07:32 AM
Had my trans rebuilt 8,000 miles ago w/131K miles. After rebuild, trans would not shift into 3rd until 35mph no matter how little throttle and trans wont downshift from 3rd to 2nd. Fluid level is good and looks clean. TV cable has been adjusted and checked many times - its very tight. Any suggestions as to ow i might resolved this or is new trans in order? Thanks.
Old 02-16-2011, 02:10 PM
SSedan64's Avatar
TV/ThrottleValve or TV Plunger in Valvebody possibly sticking/binding in TV sleeve. Disconnect the TV cable at the Carb/Throttle Body, start Engine and pull the TV cable out fully & let it snap back a dozen or so times. Maybe trash/sediment in the Valve or the Sleeve is worn causing binding/sticking.
This is also a symptom of the TV cable set too tight.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
http://www.sonnax.com/product-lines/...ion/parts/1612
700r4 2-3 and 3-4 shift problems. backyardboxwrench Transmission - Rearend 3 09-30-2010 12:26 PM
700R4 Shift Problems Sleezie Transmission - Rearend 8 06-18-2010 09:38 PM
700R4 shift problems 87firebird Transmission - Rearend 2 04-07-2009 12:05 PM
700r4 shift problems radrobnc Transmission - Rearend 11 04-04-2008 03:14 PM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
