1984 chev blazer with 700r4 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2012, 01:24 PM
when i first start the blazer it will move in all gears. after it warms up it will not move at all
Old 03-25-2012, 02:56 PM
With the info you have givin. Your low on fluid or the filter is plugged
Old 03-25-2012, 06:37 PM
that is what i was thinking but wasn't for sure. i will let you know if i find something else out or that dosent work
Old 03-25-2012, 08:38 PM
A heads-up, the more info you can supply the more accurate the answer will be. It is very hard to do diagnostics over the internet.
Old 04-01-2012, 04:06 PM
well i replaced the filter and made the pan an inch deeper since it looked like the filter was hitting the bottom of the pan. i got all gears for about a mile and now all i have is reverse and 1st gear. reverse is slow to go in and 1st is right there. the oil does not smell burnt and looks like it is still new.
1984 700r4 trans problems ccrazyhevy Transmission - Rearend 2 12-30-2011 10:24 PM
2000 Chev Blazer with 4L60e trans problems plumbright Transmission - Rearend 4 11-01-2011 09:13 PM
1984 Blazer; best transmission/rearend gear setup Wildwestshow Transmission - Rearend 7 01-31-2011 03:59 PM
1982 k5 blazer w/305 want to install a 700R4 trans krubious Transmission - Rearend 4 07-08-2010 05:02 AM
1984 K5 Blazer w/ 305 mods 91fullsize Engine 12 02-08-2010 01:15 PM
