Originally Posted by saltbob
I got this as a hot rod 350eng. Ive hard starter problems from the start
it has a 168 tooth flexplate with teeth missing as best as I can tell the
starter looks to be too far away from flexplate I am going to replace
flexplate/fly wheel does anyone know how to close the gap between
them Summit has a thicker flexplate .035 but I don't know if its enough
the starter gear only catches about one-half of the flexplate now car has
about 400HP and I think the starter gear shaft is getting bent after some
useage Old school saltbob Thanks!
Which way does it catch the ring gear when you say "half way" is that front to rear of the tooth width, or is it depth into the gear from top to root?
Bogie
