Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 corvette
Thread: 1984 corvette
Old 02-19-2012, 01:16 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
Give yourself more credit..2 flywheels IS crazy...if it was my car,I would buy a new flywheel,re-man starter,our carquest gives a lifetime warranty[new would be better if budget is not a concern] and shim kit,all for under 100 bucks,total...I would check for a bad crank thrust bearing by checking end play in the crank before installing items..if ok,then install the flywheel,making sure its not installed backwards,install starter and shim as nessessary....and if it still sounded like a meat grinder,I would find a boating friend to buy my corvette block boat anchor...but that's just me..but really,if you do those things,it should be just fine.
