Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 corvette
Thread: 1984 corvette
Old 02-20-2012, 12:46 PM
saltbob's Avatar
saltbob saltbob is offline
Last journal entry: Iembarrassed about starter problem!
84 vette
Thanks for the reply I did trip over battery charger last month on fri the 13th
fell like a brick face down on concrete two black eyes bad nose bleed had
MRI the hospital/doctor said I was OK But the way I am posting I beginning
to wonder The flywheel/flex-plate may be on backwards when I got the car I don't know the car is automatic with flex-plate/flex-wheel not a flywheel it may not be as thick as a flywheel I have a old starter here like the one I ordered
It kicked out starter gear it came out 3/4" inch that may be normal going to
see if I can rent a garage lift at a guys house and pull trans broken off teeth
on one part of wheel anyway 4-5 teeth missing Thanks again for help and putting up with my craziness I will try to get my act to together I will keep posted.
