Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 corvette
Thread: 1984 corvette
Old 02-28-2012, 04:37 PM
saltbob's Avatar
saltbob saltbob is offline
Last journal entry: Iembarrassed about starter problem!
84 corvette
This is saltbob with 1984 hot rod corvette I can't start car with new starter
from summit the starter is fine turns out between the bad starter and a lot
of teeth missing off the flexplate/flywheel the engine won't crank long enough
to start the car, I' m planning on pulling the engine&transmission together
can anyone know which is better (longer lasting) a stock heavy flywheel
or a certain metal or grade flexplate, with a price around $100-$150 , with
350 engine, summit carb. not FI, 400HP plus Also I'm planning on towing the car to Bossier City to son-in-law home garage 200-300 miles do I need to rent a car trailer or will a car dolly work, its rear wheel positrack rive.
This is a great Hot Rod site Thanks for all the help & advice.
