Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 Corvette 700 Trans Wont Shift Up
Old 06-06-2006, 08:23 PM
airworld2's Avatar
airworld2 airworld2 is offline
try this with car on a lift, or wheels off the ground rotate drive shaft listen to governor cap, this will tell you if gear is broken or apple cored. if it clicking the governor is moving. next drop the pan and look inside for dirt or metal most the time its a stuck t/v valve in the valve body. if your governor is for some reason stuck or sticking you have big trouble, 700 only hang governor from metal (bad gear train planets ring gear)
