1984 Corvette bolt ons. - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 11-17-2003, 09:26 PM
The 84 Vette was the worst, it was rated at 205 hp. What if we bolted on a pair of Edelbrock RPM cylinder heads and a Comp Cam ( 230 duration with a .480 lift )???? How much more HP or Torque would we receive???
Quick reply to this message
Old 11-17-2003, 11:54 PM
DoubleVision's Avatar
What induction system? is the computer still active? need more info here.
Old 11-18-2003, 11:35 AM
Electronic Dual Throttle Body Fuel Inj. and yes the computer would be hooked up.
So back to the original post. What was the hold back of the 1984 Corvette. If we did a cam swap and head swap...would a 1984 Vette see a significant change????
I do not have a Vette but the 1984 Corvette was slow...and now they are cheap as hell. I was wondering if a pair of Edelbrock RPM cylinder heads and a cam swap would perk that car up.
Old 11-18-2003, 02:27 PM
there isn`t much you can do for a cross fire injection system, also known as the cease fire injection. the ports in the intake are half the size of the head ports, these intakes suffer from real poor distribution problems. yes you could bolt on the heads, but you wouldn`t see much of a gain due to the restrictiveness of the intake. as for the cam, one of that duration is out, the stock computer system can`t handle duration like that without some extensive mods. to run a cam this size you would also have to bump up the compression ratio and free up the exhaust system and add a stall converter if the car`s a automatic. Most i`ve seen removed the cease fire injection and added a carb. and intake.
Old 11-18-2003, 03:46 PM
mikeweyman's Avatar
Last journal entry: 2 years later
NO BUD THE REAL GOAT OF THE VETTES IS THE 75, IT HAD THE LOWEST H.P. RATING SINCE 1954.A MERE 168 H.P. i HAVE ONE . LUCKILY FOR ME, THE MODS ARE EASILY DONE TO AN OLD 350. MIKE.
Old 11-18-2003, 07:01 PM
Hey Double V, this is interesting. I see a ton of 84 Vettes on the market for $3000 in decent shape. They already have 3.31 stock posi rear ends with fat tires..and from what I`m researching the suspension is really good. So with some mods, like a Carb, Heads, cam,mid 70`s distributer , get rid of the computer....we could actually turn that 205 hp to a 350 hp for about $1500 bucks considering the work is done at home. Agree??
I wonder where my friend 1bad80 is..........
Old 11-18-2003, 07:11 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
The only problem I see with that Keith is getting that 84 smoged afterwards. I don't know about anyone else, but here in Cali they are pretty strict about the visual aspect of the engine bay...
Old 11-18-2003, 07:44 PM
I hear you GT. I`m originally from Buffalo...besides the snow we had inspections yearly...we used to go to the ghetto and buy the stickers for about $20 bucks!! LOL
Now I`m down here in Orlando and there is NO laws anywhere that are enforced. I have a 86 T/A that wouldn`t even pass 1960 emmissions in Cali! I didn`t want to leave the snow, I left the inspections!
Isn`t there a way around the inspections in Cali?? You guys don`t have a ghetto where you can get your vehicles inspected?
There`s got to be a loop hole.......
Old 11-18-2003, 10:42 PM
Rubberman2003's Avatar
On my 84 camaro, when i swapped motor i took all my EGR stuff off (SHAME ON ME) they are in a crate in my shed bad bad rubberman BUT i live in Ohio, enough said.
Old 11-19-2003, 04:07 AM
New Member
i converted my 84 vette to tpi, i used a harness and intake setup from an 86 vette put in roller rockers and an emissions cam from crane and it woke it up. but u have to change all the accessory brackets and fan shroud and hood to use the tpi. it was a lot of work.
Old 11-19-2003, 10:26 AM
The only way to get around it is to shell out some cash to the right person. The hard part is finding that right person. Not to many guys out there are willing to loose thier license for a few bills. It was pretty easy a couple of years ago, but with everything being so strict, it's easy for them to get caught, i guess.
Old 12-27-2014, 03:29 PM
No. You can leave the crossfire injection. If you dont care for crossfire stop talking. Resize the intake ports the match the heades port the throttle bodies to 2" and get a 86 fuel pump. I just threw a com cam in my 84 vette#249-CL12-364-4 with this setup and a performance chip, 285hp if you want do an x ram and see i bigger difference.
Old 12-27-2014, 03:49 PM
Proud LOSER
He did stop talking, 12years ago in fact....I'm sure he figured it out by now.
The Following User Says Thank You to bygddy For This Useful Post:
vinniekq2 (12-27-2014)
Old 12-28-2014, 01:58 AM
pricesgarages's Avatar
been awhile since id messed with a cross fire but u can gain a lot by poring the intake it is very restrictive there was a company that made a larger throttle bodies for them also change to a fuel pump from a tuned port other than that heads would help 84s had 76 cc id go with a l98 58cc or edelbrock performer 60 cc the rpms would be over kill for it a msd 6a box would help some big thing with c4 vettes is the gears they were usually 2.59 or 3.07
Old 12-28-2014, 02:04 AM
Proud LOSER
See post#13 josh.....
Closed Thread
