Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 full size blazer with 350 chevy crate engine questions
Old 01-08-2013, 12:21 PM
84blazer 84blazer is offline
hello fellow chevy fans,
i'm new to the restoration game, and my first project is a 1984 full size blazer. I recently installed a crate motor i puchased from a friend that he had installed in his blazer also. But what i want to do is go through the motor and set all the specks to where they should be, because the guy i aquired the motor from although an accomplished gear head, i don't want to run the motor to his specs. What i need to know is where to put the timing, fuel mixture, plug gap, and what ever else i might need to know to make this motor run efficiently.
what it is, is a small block 350 with an rv cam, carter carb, weiend mid rise intake, old school chevy ram horn headers, the distributer is electronic, i'm drawing a blank on the proper name. well thats what i have thanks for any help i appreciate it.
