Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1984 full size blazer with 350 chevy crate engine questions
Old 01-08-2013, 12:54 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
put the fuel mixture to a ratio of 13:1 through the entire RPM band set at wide open throttle under a simulated load that is equal to your truck.
start with the timing at a total advance of 34 degrees set at 3,000 RPM or where ever your system peaks.This is with the vacuum advance disabled.(re establish vacuum advance system after tuning)plug gap ,use .035
