Thread Tools Search this Thread share on Facebook
  #1
Old 01-07-2012, 04:25 PM
mvara71 mvara71 is offline
1984 Gmc High Sierra
Hi guys I am going to need some help I am transferring all my parts from a 1984 Gmc High sierra to a donor cab, because IT was cheaper than just replacing the inner and outer rocker panels and corner caps my interior is Red and the donor Cab is velvet blue is in good condition but not my style and someone actually had paid a lot of money to have this done all over this cab. I am trying to remove the dash, or does it even come out, i manage to remove the to 1/2 bolts attach to each side and three small bolts on the metal of the dash, (the dash pad is out) I can move the dash but still it will not come out, should I remove the winshield and will i find more bolts? thanks and hope someone gets back to me.
Register now (free) or login to remove ads
Old 01-07-2012, 06:06 PM
BIG TEXAS BULLIES BIG TEXAS BULLIES is offline
Last journal entry: 1983 GMC
If It Moves Freely Then I Dont Think It Has Any More Bolts. Try Lifting The Front Of It Up A Little And Pull Towards You It Has Some Clips That Go Into Some Cut Outs Under The Dash. Hope It Works For You
Old 01-08-2012, 12:37 PM
84 Gmc dash panel removal
I try to to that today , but the dash panel would not come out, so I broke the windshield just to see what was under it . (the windshield was crack to begin with) and I found out that is welded, so I am thinking of cutting it, and replace it with the other dash panel and overlap the metal and use rivets, besides it will be cover by the dash pad.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1984 Gmc High Sierra"
ThreadThread StarterForumRepliesLast Post
95 gmc sierrajr69Transmission - Rearend201-08-2011 12:28 PM
need help changing out sterring collumn on a 1979 gmc high sierra half ton 4x481scottsdale400Suspension - Brakes - Steering410-10-2010 10:14 PM
th700r4 (1984) shift only high rpmChris34Transmission - Rearend709-08-2009 01:41 PM
94 gmc sierraspydiTransmission - Rearend312-05-2007 05:14 PM
BBC In a GMC Sierra - will it fit?69ChevelleAddictEngine407-09-2006 08:44 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
