1985 astro 700r4 shift problems
My 1985 astro that i think has been stood a while is acting strange, It seems fine for the 1st few minutes and changes up gears fine then its like its kicked down a gear and then a while after that its like it stays in a low gear and slips.
Any suggestions please? sorry if its been covered, i've had a look back a few pages. Cheers Smit |
one point to note is the dip stick has an end welded on it so i'm unsure how much fliud should be in there, were emptying it and cleaning the filter, does anyone know how much fluid should go back in please?
what is the history of this trans? Mileage , recent repair work?
Low oil will cause slipping. It may be causing a low pressure problem if the fluid is getting air into the system
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I've just bought the van as a none runner and have no real history of it
its now running nice other than the transmission!
em thats not so easy or cheap in the uk
after dropping the pan and filter and letting it sit and drain for about 10-15 min it should take about 5-5.5 quarts but i would suggest getting a new dip stick 700 are picky as little as 1/2 quart other wise if it still does it after you fill it with the 5-5.5 quart and still use the old stick just add another quart if it is good get a new stick if it does the same get a rebuild
Read the dates on threads. This is a 1.5 year old thread.
| 1995 Dodge Stratus Shift Problems | Not A T 25 | Transmission - Rearend | 2 | 06-09-2007 02:27 PM |
| 1993 4L60 700R4 problems. | steve40th | Transmission - Rearend | 0 | 05-30-2007 10:59 PM |
| Recommended ATF 1985 700R4 | AngliaBob | Transmission - Rearend | 2 | 11-12-2004 11:35 PM |
| 700r4 problems | Thacolbster | Transmission - Rearend | 5 | 01-14-2003 01:30 AM |
| 700r4 problems | shane horton | Transmission - Rearend | 2 | 10-27-2002 07:37 PM |
