1985 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 09:50 AM
1985 camaro
can some one help i have a 1985 camaro on the rear axle it has 91a c094 2 or 9ia c094 2 is this the right axle for it and what gears it has
Old 05-30-2013, 11:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Maybe this will help, if you find your differential, compare it to your RPO codes inside the glove box to see if it's stock. Google VIN codes for your vehicle.
http://chevellestuff.net/qd/generic_rear_axle_info.htm
Semper Fi
Old 05-31-2013, 05:07 PM
1985 camaro
thanks a lot is 3.08 gears good for racing or for long distance driving
Old 05-31-2013, 06:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What RPM your motor is turning at speed is defendant on final transmission gear ratio, rear-end gearing and rear tire diameter. IMO 3.08 gears are better for the street than strip. They could work in a very light car for weekend fun, not a serious contender. Take a look at the attachment.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
plumcrazyopa (05-31-2013)
1985 chevy camaro drawde2474 Transmission - Rearend 3 04-18-2006 08:38 PM
1985 chevy camaro drawde2474 Introduce Yourself 1 04-17-2006 03:39 PM
1985 chevy camaro drawde2474 Introduce Yourself 1 04-17-2006 03:36 PM
1985 camaro? Super Chevy Engine 6 03-27-2006 12:31 AM
1985 camaro box query Phil 1 Transmission - Rearend 4 09-23-2002 08:33 AM
