Weak spark is usually a sign of a bad coil or bad ground somewhere.
The fact you have spark tells you most likely the internals of the distributor are working.
Artificial Intelligence is no match for Natural Stupidity Chet |
Try dumping a teaspoon(no more) of fresh gas into the carb and turn it over quickly before you put the air cleaner assy back on. Only blip the throttle quickly once. That should tell you if its in the ignition or fuel circuits. If it tries to start, you may have bad/old gas or some other fuel type problem. If it doesn't try to start, look at your ignition.
FWIW ssmonty |
Orange, yellow spark means weak spark.
If the engine has that many miles on it the timing chain is completely shot. Changing it wouldn`t be a bad idea. Quadrajets are not junk. They are the best carb ever made and many will testify to that statement. They can and have been used successfully on the street and on the race track. I learned over the years what a junk carb is and that`s a Holley, they are very cheaply made and have poor quality control. Just because you don`t understand a Quadrajet don`t make it junk. If your Quadrajet still works after that many miles, I wouldn`t call it junk. You would have never gotten that many miles out of a holley. |
Update: I did put 5 gallons of fresh gas in The Wagon and I know for a fact it was almost empty. I still tried to spray starting fluid in the carb and she still didn't change. I seriously doubt the timing set is so worn out that it failed to start the day after it parked fine with no abnormalities. I'm not saying you're wrong, I'm just trying to squeeze a few more tanks of gas out of her since she is the only truck I got and I need to take a 350 to get machine work done on. I'm almost dead set on low compression. A new question would be should I soak the rings over a day or two with some Marvel Mystery Oil (an old trick I learned) and change out the oil and put in some Cylinder Restore? That should give me a good shot just shy of rebuilding the engine... I hope. |
I was saying it`s likely the weak spark is why it won`t start. When you get a weak spark, it can be it`s only sparking every other revolution and when you perform a spark test what you use is less resistance than a spark plug so it`s likely to ark it, but not the plug itself. Electricity is smart and lazy, it will always take the path of least resistance. Next is low compression and a bad timing chain is a double whammy. Using any kind of engine additive unfortunately won`t bring it back. Even if the engine has 5:1 compression it`ll still start if it`s got air/fuel and spark. One of those three your not getting. In the past I`ve seen Oldsmobile 260`s with 150,000 miles have 60 psi cylinder pressure left, they would still start, but wouldn`t rev over 2500 rpm and wouldn`t go over 25 mph but as long as it had air/fuel and spark, it would still run.
Update
I can understand the aluminum cam gear at least compared to my dad's old V6 Pinto having nylon timing gears. Well I wrestled the new double roller timing set on there and then I felt like rubber so I called it a night. Tune-in later folks. Last edited by 68NovaSS; 10-01-2011 at 07:19 PM. Reason: Profanity. Please see: general board guidelines. |
More than likely that timing gear was Nylon coated, yes, GM did the same thing. Now the next part of the problem. The nylon gets brittle from heat and wear, breaks off, falls into the oil pan, the oil pump sucks it up into it`s screen which kills the oil pressure until the point enough of it`s on the screen with a little sludge and no more oil pressure. Next is the engine locks up and the ball game is over. Seen that happen on countless engines, especially fords from the mid 70`s. You`ll have to remove the pan and clean the oil pump screen. If not, your running a time bomb. Sorry I don`t have better news.
Thank you
Thank you for shaking some sense into me. I didn't know those were nylon coated. I was thinking at first to drop the pan to change the oil pan gasket for good measure, also to fit the timing cover in place but I squeezed that back in without having to do so. I will put that on top of the to-do list right underneath "get-'er-runnin' ". I'm still not certain if she will crank up since I'm most likely still producing an orange spark. I did find a corroded ground wire right by the t-stat housing and I'm in the middle of fixing that now. Here's hoping...
She lives!!!
The timing set fixed it! She ran beautifully and so very strong and then she didn't even make it a half-way down the street
I found my temporary fix finally wore out on my gas tank. I had a jbweld patch on a hairline crack for over 3 years now and then all my gas was gone by the time I left the driveway. BUT SHE LIVES AGAIN! Time for a new gas tank and some more TLC. Thank you for your wisdom doublevision, it helped tremendously ![]() On another obvious note, I had no weak spark. I stupidly didn't realize that my in-line spark tester is always going to flash orange. After I ran the car, the clear dist. capwas showing blue spark to each contact. Glad it was one thing and nothing else.
Last edited by ViperMonster800; 10-02-2011 at 06:50 PM. Reason: forgot to add another comment |
| 1985 chevy 350 | aarias-31 | Engine | 5 | 05-26-2011 04:02 PM |
| How many miles of city driving to break in, before freeway miles | TNshadetree | Engine | 6 | 09-24-2010 05:37 PM |
| ******* FOR SALE!!!!!!!!! ********* orig. miles | crowncobra | Engine | 3 | 10-18-2009 02:59 PM |
| 1985 dodge no start | daveman1966 | Electrical | 5 | 08-26-2008 06:28 AM |
| SBC in a 1953 Chevy AD (orig. brake pedal?) | madnicholas | Engine | 0 | 09-08-2007 12:00 PM |
