1985 chevy C-10 shaved door handles
Thanks. I am using Spal brand and according to the directions we are using the correct wire for channel 1. I just dont see any way of mounting the selenoid to the side of the door where the latch is. I know it makes more sense to mount therebut, I just cant see it. I am also afraid if we disconnect the connecting rod from the interior handle we will never get it back on the cheap little plastic clips or where we could get another clip if we break it. Do you think the nut I welded on the connecting rod will work? Are we doing something wrong? I thought by using the bike cable in the housing that the cable could be more forgiving as far as the way the motor mounted and the line the cable traveled. The cable is not in a straight linebut, when disconnected from selenoid it moves freely in housing in the same position. We appreciate all the help Deadbodyman!
