1985 chevy c10 1/2 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2010, 08:55 AM
I just did my brakes on my truck and started the bleeding process when i noticed i wasnt getting any fluid to my rear drums. i checked my master cylinder and losened the lines and found fluid leaving the master but not reaching the rear.
i had people say its my proportion valve and needs to be reset. I just wanted to know if antbody here knew how to do that? Its located underneath my core support
Old 05-21-2010, 12:56 PM
Unhook the line at each end and blow some air through it
Old 05-22-2010, 10:44 AM
fast68's Avatar
likes chevy trucks & boobies
try the button on the valve see if you can move or center it maybe
it could be stuck but its not usual or common
sometimes its a real pita to get lines to start bleeding if they are totally full of air
let it run out over a few hours with bleeders open and cap off the mc
to get it going
if you can get a helper then have them push pedal down and keep down while you loosen up one bleeder and remove it
then put a finger tip over the bleeder hole and let the helper careully press and depress the pedal over and over until you get air and fluid out
make sure the mc is bled out properly
if not then it wont work anyways
i bleed them on the vehicle
i remove line and put finger over the port hole and let someoen push pedal down
put rag over it all it will spray mess
cover with finger tip tight when pedal comes back up
so you dont suck in air
this will bleed the mc good so it will bleed the lines out
if ou dont run the mc dry and you dont allow air to suck into a bleeder port then you will get it
also if you dont have a leak or bad line somewhere
wont bleed then either
Old 06-01-2010, 09:21 PM
chevy c10 throttle sticking
i just installed a 1 inch carb spacer under my quadrajet and now my throttle is sticking anybody know why?
Old 06-02-2010, 11:54 AM
shoot some penetrating oil on it and put a stiffer spring in, check for anything grabbing the throttle as it returns.
'55 Chevy 1/2 ton rear end I.D. rlhoward59 Transmission - Rearend 1 08-20-2009 04:19 AM
E-brake for 49 chevy 1/2 ton. HoppalongC Suspension - Brakes - Steering 1 08-06-2009 02:39 PM
61 chevy 1/2 ton rear axle goneinsixty Transmission - Rearend 1 02-18-2009 08:57 PM
Tach in 76 Chevy 1/2 Ton Phyrkrakr Interior 1 05-01-2003 04:34 AM
48 Chevy 1/2 ton V8 engine placement tomy2tone01 Engine 3 12-09-2002 01:59 PM
