1985 Dim Lights on Dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 11:02 AM
Hi, I have a 1985 corvette and the dash lights dim out. When you first start it up the lights are bright and then they dim out,and the dim switch seems to not work at all when moving it. Any help would be very appreciated. Thanks. Bill
Old 09-07-2010, 01:03 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The headlight switch has variable resistor that changes value as you rotate the switch thus dimming the lights.
Most likely the switch is bad but it could be a bad connection.
vicrod
Old 09-07-2010, 04:59 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
I'm going to give you a quess here.If your dash is bright when you start up and then goes into a backlite position,you might have something like an LCD relay that may be defective.The purpose of this relay is to switch over to a dimmer phase when set on autolamp.
Paisano
Old 09-07-2010, 07:20 PM
T-bucket23's Avatar
Wiki Edits: 26
Most likely the dimmer switch is no good and once it is on it heats up and resistance increases and causes the lights to dim. I would try a new dimmer switch. You may also want to check all the grounds for the dash. Corvettes are prone to grounding issues
Chet
flickering dash lights tjh211 Electrical 5 05-06-2007 06:28 PM
No lights on dim lanierledford Electrical 5 09-29-2006 06:37 PM
Dim Dash lights Torino1 Electrical 2 01-14-2006 06:36 AM
changing dash lights to LEDs need some help mickey1031 Electrical 4 10-18-2005 09:55 PM
Dash lights fade in and out firebirdfanatic Electrical 10 10-02-2003 09:27 PM
