1985 ford v8 my buddys - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 04:33 AM
clutch is really stiff..{hard to push i guess}and dont go in gear sometimes..hydraulic
Old 06-17-2013, 08:27 AM
vinniekq2's Avatar
warn out? broken spring in clutch hub?needs adjusting?worn clutch pedal assembly?clutch master or slave leaking/bypassing?
Sixshooter45's Avatar
I'm sure this will get moved. But be more specific, I'm not the guy to help with this, But I've learned if you give more info about what your working on the folks around here are more than happy to help.
Best of luck!
1985 ford 351w buildup questions esser89 Engine 1 05-10-2011 09:33 AM
1985 ford winsdor rockers...How Strong ? Haulin327 Engine 6 10-18-2009 03:30 PM
Buddys car having issues Mechassault_x Hotrodding Basics 1 04-26-2007 09:21 AM
1985 Ford Ignition Problems Bert420Chillin Electrical 5 10-14-2005 12:44 AM
1985 Ford F-250 Bassman Suspension - Brakes - Steering 4 03-29-2004 05:53 PM
