1985 grand prix - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 01:57 PM
1985 grand prix
I have a 85 grand prix v8 an I'm having problems!! When I start it smoke comes out the exhaust for a while then it stops. Also, when I drive for a period of time a tickin noise starts an the more I accelerate the louder it becomes. It did this for a while because I was in the middle of a traffic jam an it eventually started smoking so I pulled over an cut the car off. I put antifreeze in an tried to start it up an I guess it was too hot at the time because it wouldent start but after a while it eventually started but smoked again when I stopped at a light. This is a lot going on an I need help!
Old 08-23-2012, 04:20 PM
poncho62's Avatar
Wiki Edits: 5
Typical signs of leaky seals/gaskets and a well worn engine...How many miles on it?
Old 08-23-2012, 04:44 PM
80xxx but it sat for a very long period of time
Old 08-23-2012, 05:18 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
If you added coolant, then it has a head gasket problem or a cracked head or block. That is why the antifreeze is disappearing and you see white smoke. Then the engine overheats and the oil thins out, and lifters start making noise and I am sure the engine prolly starts to knock from detonation caused by overheating.
You arent seeing coolant leaking on the ground ....right?
Fact is stranger than Fiction
Old 08-23-2012, 05:27 PM
Exactly!! So the fix to this would be what? Buying a new engine or is this something that can be fixed without buying a new engine
Old 08-25-2012, 06:02 PM
******************************** Wat I should do with it! Is it worth fixing or sale it??
Last edited by poncho62; 08-25-2012 at 06:27 PM. Reason: classified ads not allowed...use the classified section...thanks
Old 08-25-2012, 07:17 PM
LATECH's Avatar
Get a good used engine and put it in.
Old 08-25-2012, 09:31 PM
Banned User
The other thing to check is to temporarily disconnect the vacuum modulator and see if the smoking stops.
P.S. 85 means it has the chevy engine, so if it is in fact a coolant leak then it will be easy to drop in a replacement engine.
engine noise
1985 pontiac grand prix idle rpm JLBpontiac350 Engine 2 05-03-2011 01:01 PM
79 Grand Prix MrAMH Engine 36 08-16-2010 09:16 PM
what would you do with this 78 grand prix ? fast68 Hotrodders' Lounge 22 07-09-2006 05:18 PM
69 Grand Prix RYAN WALTERS Introduce Yourself 1 03-05-2006 02:29 PM
81 grand prix v6 to v8 grandprix601 Engine 10 10-15-2004 11:35 AM
